I thought that Italy has a higher rated 2-pin Europlug-like connector too ? 10 A ?
Contour plugs don't normally fit italian sockets as the pins are too fat for the lower rated sockets and not spaced far enough apart to fit into a 16A outlet.
I have seen schuko/italian comination outlets in italy though. Quite a smart design. It's basically a normal schuko socket with a hole at the centre that accepts the ground pin on the 10A italian plugs.
I really can't see the non-CEE 7/7 systems, other than the UK/Ireland (because of the ringmains quirk) surviving. With the addition of various Eastern European countries, all of which use Schuko or French sockets, the non-CEE 7/7 countries are in a total minority. CEE 7/7 is well established as the defacto European standard. The Danish, Swiss and Italian systems really don't offer any advantages. If Switzerland or Denmark for some reason wanted to keep polarised outlets they could always adpot the French UTE / CEE 7/V system rather than the unpolarised German VDE CEE 7/IV.
I honestly can't see why the UK and Ireland can't simply use fused schuko outlets either. There's no reason why companies like MK etc couldn't produce sockets that conform to CEE 7/7 and also maintain the safety features of a British outlet. Manditory shuttering, built in switches, even little neon lights to tell you that they're on [Linked Image] Just put a 16 amp fuse into them on the live side.
UK wall boxes are an unusual, non-European, design anyway so only BS CEE 7/7 outlets would fit and non-fused imposters would be very easy to spot. Just insist that they have some clearly identifiable moulding like "For use in UK & Ireland" visible on the inside of the outlet.
There would be no reason to phase out ring mains nor to have fused and non fused outlets.. Just like today, we use fused plugs regardless of wheather they're plugged into radial or ring circuits.
Electricians are not going to start installing unfused sockets on ringmains and DIYers can already install a whole variety of unfused outlets directly onto ring mains should they be stupid enough (BS546 or just make a trip over to callais and buy a French outlet or two... or as I've seen here once or twice; blue CEE 17 sockets with no fuse on a ring main in a shop!) So I can't see why there would be any increased risk.
The vast majority of UK appliences are not properly fused anyway. From what I can see, 13A fuses are popped into many plugs for TVs, VCRs, Radios etc.. which isn't really a huge problem as they're all designed to be plugged directly into 16A sockets anyway.
[This message has been edited by djk (edited 03-22-2004).]
