hi ch :
did not get chance to see ya for long time but i will quickly point it here in north amercica . what you show the "clock plug "chart for varis voltages they are simuiar to north american voltages also and i did look at one of my catalog book and it show the same way of the plugs but you have 3 addtional voltage what my north america book not show on listing but most twist lock plug in north america are colour coded by voltage also bleu = 120 volts yellow = 240 (208 ) volts orange 480v grey 277 volts but i will find more on twistlock plugs but the international pin and plug set up are common for both side of "pond" and of course i remeber the french voltage plug it is the same what you say about it
merci marc
