The pins of our old plugs were solid the first 5mm where they emerged the case, then they had a small slot. It looks as though they'd been partially cut in halves from the tip with a very thin saw blade.
Many types of British 2 and 5A plugs were similar. If a plug was a loose fit in an outlet, you could just pry the pin open very slightly to improve the contact.
