Sorry but going to 460 will not decrease your total load. Volts and amps are inversely proportional. Your motor will pull less amps at a higher voltage, but the load is the same.
Look at the label on one of your motors.
It will be listed as dual voltage - 230/460.
The amps go down when the voltage goes up. But it is the same size motor.
