Wolfdog,
I don't want to decrease my total load. I want to add two 50hp motors, remove a 40hp motor and change it out with the 25hp that I am using to create my third leg. At 230 volts all of these motors would pull to many amps. At 460 volts they would not. I know about the inverse relationship between amps and volts. I also know that volts X amps = watts. So if I can transform the 230v to 460v and add the other motors I would be using around the same # of amps but about twice as many watts. Does the 200 amp service or transformer limit the # of watts I can use in an hour, and if so would using twice as many as I am now exceed that limit?
Hillbilly
