Alan, this is an un-finished version of "platform framing", balloon framing's younger wiser brother.
![[Linked Image]](https://www.electrical-contractor.net/ubb/biggrin.gif)
(It is missing fire blocking at the mid-point of the wall.)
(For our European friends... Not sure if this type of framing is popular there.) It is based on the balloon framing technique, except it stops at each floor with a top plate, and rim joist for each floor, then starts again on the next floor. The floor and roof joists sit on top of the top plate, and nailed to the rim joist. And correct, still is not at full strength until the walls are complete. The material, and method of attatchment will determine its final shear strength. Like the semi-finished example in the backround of pic #1.
Where I am in earthquake country, certain walls at engineered to maximize that shear value. "Shear walls" usually have simular 16" on center 2x4 or 2x6 framing, then have cross grained multi-ply plywood nailed in a tight pattern on the edges, and each stud with 10d nails, on one side or both. Often they will have hold-down brackets and those are bolted to the top, and bottom plates though to the foundation. And on regular walls from the foundation, the sill plate is bolted down, as shown in pic #2.
Heres a nice animation describing shear wall basics. (wait, it takes a bit to start.)
http://www.pbcgov.com/pubsafety/eoc/HowTos/walls.htm Stamcom, its not so much an east west thing, more to do with the era of development. Many buldings in the west were balloon framed before 1920. Like much of San Francisco and the Bay Area. Even some of the older Vic's, and Ed's in and around San Diego and Coronado. (What are left of them)
[This message has been edited by e57 (edited 09-12-2005).]
