What kind of terminal do they use? Screw or also the stab-in quick connect type?
The very common Kopp brand surprisingly still have screw terminals, even quite nice ones. Recently I installed a flush mount three way receptacle that fits a single gang box (brand new from the store) and it had screw terminals. The way the terminals were built indicated you could just insert a straight wire and tighten the screw, upon trying that the wire escaped from under the screw head. So I pulled the wire back out again, bent it around the screw and everything worked fine.
Last week I tried using one of the Hofer screw terminal receptacles... and immediately sent the entire pack to the trash! Very thin brass everywhere, the plastic so soft the compression plates would spin freely when the screw was tightened... no way that could result in a safe and solid connection! So an 8 pack of never used receptacles ended up in the trash can... and if I _ever_ find the other pack we bought a year ago it's going to go the same way, i swear!!!
