Ditto about the ground in the xfer switch... Those conductors seem a little on the light side for 800A
Tell me if I'm seeing this right... Did someone come across that burnt connection in the 2nd pic and just cover it with some hot glue???? Are wirenuts or choc-blocks or whatever you guys use getting scarce?
