0 members (),
148
guests, and
25
robots. |
Key:
Admin,
Global Mod,
Mod
Posts: 2,723 Likes: 1
Broom Pusher and Member
P.S. In Regards to the Utility Co. landing Line C as the High Leg, I was thinking that this was done in the Meter section just to keep it "Away" from the "Usable" Lines, which run through the KWH Meter.
If you notice the KWH Meter used on the 4 wire Delta, it is a Single Stator Meter - typical of the common 1 Phase 3 Wire setups used in Residential Metering for 200 Amps and lower, or the ones driven by CT's in applications of 400 amps and higher.
Just my thoughts - not necessarily the method to the madness!
Scott S.E.T.
[If anyone can find out the real reason this is done, please post your findings here!]
Scott " 35 " Thompson Just Say NO To Green Eggs And Ham!
Entire Thread
Ok theorists, help me out
Steve Miller
05/01/02 12:46 AM
Re: Ok theorists, help me out
Steve Miller
05/01/02 12:50 AM
pauluk
05/01/02 08:46 PM
Steve Miller
05/02/02 03:00 AM
Bjarney
05/02/02 03:23 AM
pauluk
05/02/02 07:45 AM
Bjarney
05/07/02 03:08 AM
pauluk
05/07/02 11:35 PM
Bjarney
05/12/02 01:23 AM
pauluk
05/12/02 08:43 PM
hurk27
05/15/02 06:11 AM
pauluk
05/15/02 07:15 PM
hurk27
05/16/02 05:14 AM
pauluk
05/16/02 09:36 PM
Scott35
05/18/02 06:27 PM
Bjarney
05/18/02 07:29 PM
pauluk
05/19/02 08:34 PM
Bjarney
05/19/02 10:05 PM
Bjarney
05/20/02 03:08 PM
pauluk
05/20/02 06:30 PM
Bjarney
05/23/02 06:23 PM
JBD
05/23/02 08:48 PM
pauluk
05/24/02 09:56 AM
resqcapt19
05/24/02 11:49 AM
JBD
05/24/02 01:11 PM
resqcapt19
05/24/02 02:47 PM
Scott35
05/25/02 03:28 AM
Scott35
05/25/02 03:35 AM
pauluk
05/25/02 01:33 PM
Bjarney
05/25/02 08:13 PM
Bjarney
05/25/02 08:55 PM
