0 members (),
361
guests, and
33
robots. |
Key:
Admin,
Global Mod,
Mod
Many thanks for all the info. I'm always interested in the origins and historical development of different systems.
I ran across your 4-w unbalanced delta here a few months ago in relation to the use of orange to identify the high-leg. I can see how it originated to provide 120 from a simple 240 delta, but it seems quite an odd system from a British perspective. Do you know when these systems were last installed as standard? I think somebody else said that even a regular 240V delta would be rare now and that all new commercial LV supplies are a simple 120/208 or 277/480 Y.
We have some isolated houses on a 1-ph xfmr fed from two legs of an 11kV delta, but the 2-wire residential service here is usually tapped off a 240/415 Y distribution network, the same xfmr often feeding 3-ph power for commercial buildings, as you mentioned for Europe. The 240 nominal became our national standard by the early 1970s; prior to that it varied 200 to 250 in different areas.
Most of Europe standardized at 220/380, although they had some older 127/220 systems in some areas until quite recently. There is now a move toward a common European standard of 230/400.
The main difference in this respect between the U.K. and mainland Europe is that only a very large, power-hungry house would be fed 3-phase here, but on the Continent 3-ph is very common, although often of low power rating (e.g. a lot of older homes in France are fused 20A per phase). Many electric ranges in Europe are 3-ph 5-wire.
I'm not aware of any 1-ph 3-wire AC systems ever being used over here, although 3-wire DC (200/400 to 250/500V) survived in the older parts of some towns until the 1960s.
The "cut-off" point for safety in homes here seems to be regarded as 250V. That was the highest residential utilization voltage under the old 250/440 Y or 250/500 DC systems, and still figures quite prominently in many parts of our code (e.g. 250V max. on regular lampholders).
On the very rare occasions where 3-ph is introduced to a domestic system, the regs. specify quite a number of rules to minimize the risk, such as the requirement that all receptacles in one room be on the same phase.
The use of a greater number of smaller xfmrs in a typical American neighborhood is one of the things I noticed the first time I was over there. Interesting that the primaries on some of these are fed phase-to-neutral; I've not been involved with the HV distribution side of things here, but I'm not aware of any such HV feeds in England.
Entire Thread
Ok theorists, help me out
Steve Miller
05/01/02 12:46 AM
Re: Ok theorists, help me out
Steve Miller
05/01/02 12:50 AM
pauluk
05/01/02 08:46 PM
Steve Miller
05/02/02 03:00 AM
Bjarney
05/02/02 03:23 AM
pauluk
05/02/02 07:45 AM
Bjarney
05/07/02 03:08 AM
pauluk
05/07/02 11:35 PM
Bjarney
05/12/02 01:23 AM
pauluk
05/12/02 08:43 PM
hurk27
05/15/02 06:11 AM
pauluk
05/15/02 07:15 PM
hurk27
05/16/02 05:14 AM
pauluk
05/16/02 09:36 PM
Scott35
05/18/02 06:27 PM
Bjarney
05/18/02 07:29 PM
pauluk
05/19/02 08:34 PM
Bjarney
05/19/02 10:05 PM
Bjarney
05/20/02 03:08 PM
pauluk
05/20/02 06:30 PM
Bjarney
05/23/02 06:23 PM
JBD
05/23/02 08:48 PM
pauluk
05/24/02 09:56 AM
resqcapt19
05/24/02 11:49 AM
JBD
05/24/02 01:11 PM
resqcapt19
05/24/02 02:47 PM
Scott35
05/25/02 03:28 AM
Scott35
05/25/02 03:35 AM
pauluk
05/25/02 01:33 PM
Bjarney
05/25/02 08:13 PM
Bjarney
05/25/02 08:55 PM
