Greg:
Following the comments from you, and Reno, you guys are talking about micros that have a 120 volt nominal AC output, correct??
I have only seen 240 volt nominal micros, that are common on solar installs.
I guess if you had a 240 volt UPS, and a compliant way to connect it as a 'utility' source, it should trick the inverter to provide solar power?? What say you??
