I like the conduit work Paul!.
Man, what a difference white conduit makes, over the grey stuff most commonly used here.
In pic #5(first lot), is that a man-hole cover that that wiring runs over?.
On the ceiling?!
I was using the term "man-hole" in the context as it is used locally, meaning any access way to get go a roof void or under-floor area.
Final question,
Did you use 2+E cables or conduit wires inside the conduit?.
