0 members (), 1,098 guests, and 8 robots.
#99625 08/22/06 01:08 AM
is 200.6 ment that you cannot re-identify a colored conductor(black,blue,red,ect...)smaller than #6 in pipe
to a grounded conductor using white tape???
thanks,
H20
Workgear for Electricians
#99626 08/22/06 06:27 AM
yes
#99627 08/22/06 06:56 AM
I agree with Don
and it is done all the time
Charlie
#99628 08/22/06 08:21 AM
thanks,
H20
#99629 08/22/06 08:42 AM
I'm not at all sure that this wording in the code was deliberate. I agree, technically re-identifying a wire to make it white is not allowed.
Personally, I disagree with this rule. Argument aside, not a single supply house here carries #6 or #8 wire in any color but black. Ironically, sometimes the box dtores do!
Frankly, I am simply delighted when ANY attempt is made to properly identify conductors.
#99630 08/22/06 09:17 AM
Amen to any attempt to identify the conductors. It seems to be too much trouble to go the extra foot to properly identify conductors when their purpose is not clearly demonstrated or seen.
#99631 08/22/06 10:37 AM
I think the box stores carry colors because a homeowner is more likely to buy cut wire in these sizes. They also need the help to avoid confusion. Although I have seen pros who should know better get wires misidentified.
Boom!
#99632 08/22/06 12:05 PM
Simple personal opinion is it wouldn't be a bad idea to change the minimum size allowed to number 8. #10 and below is pretty common stuff on the shelves. The rule apears to have been written with big shops in mind. The ones that will carry lots of inventory. Time for an old quote from the past " Its the economy stupid"
#99633 08/22/06 06:26 PM
I would be more inclined to believe it is the wire mfg that drive these types pf code issues, if all the mfg stopped making white insulation for 8AWG and 6AWG the languge would change.
Just a thought
Charlie
#99634 08/22/06 09:31 PM
You guys want some cheese with that whine?
[This message has been edited by George Little (edited 08-22-2006).]
George Little
