0 members (), 101 guests, and 109 robots.
#95789 10/06/05 08:36 PM
Where in the NEC does it cover wiremold?
Workgear for Electricians
#95790 10/06/05 08:50 PM
Is what you are asking, is, where in the NEC does it cover raceways?
I'll guess 300.18.
And 300.12.
But wait for the experts....
Dnk......
[This message has been edited by Dnkldorf (edited 10-06-2005).]
#95791 10/06/05 09:32 PM
Wiremold, and like products, are not considered to be a "wiring method." Rather, they are considered as a complete assembly to be an "appliance." A glorified extension cord or power strip, if you will, but one suitable for permanent mounting.
If you wonder how Wiremold can ignore box-fill rules, this is why,
#95792 10/06/05 09:36 PM
ARTICLE 386 Surface Metal Raceways
ARTICLE 388 Surface Nonmetallic Raceways
Curt Swartz
#95793 10/06/05 09:36 PM
I see, it's because I need to add one more circuit to my existing panel. The apartment is not mine, so I need to do it in a way where I'm not fishing through walls (that much) and tearing walls out to mount boxes and run conduit. So, I believe wiremold is the easiest way for me, since the run is only going to be about 7ft of mold, 2 #12 conductors, and a #12 grounding conductor for a 120v, 15A, single receptacle to power a secondary refrigerator.
#95794 10/06/05 09:38 PM
Ah, that's another thing, I wanted to know the NEC "term" for it exactly, thanks.
#95795 10/07/05 12:19 PM
Question, would the proper way to feed a dedicated circuit through a wiremold raceway be to have a NM single gang box, mounted inside the wall, of course to a stud, then feed the circuit through there to a wiremold single gang NM box mounted above it (to be flushed with the wall surface) acting like a junction box and connect the wiremold raceway from there?
#95796 10/07/05 01:10 PM
DS,
Wiremold makes a box for this particular purpose. It's called a "starter box" and has an open back and is designed to mount over a wall box.
Peter
Peter
#95797 10/07/05 01:20 PM
Indeed, just got the email from wiremold. This is the case.
Thanks to all.
#95798 10/11/05 01:01 AM
That would be 310.8(B-C).
Ya gotta use the right insulation in damp and wet areas so the wire doesn't get moldy.
