0 members (), 444 guests, and 10 robots.
#95560 09/21/05 05:32 PM
Does anyone have any information on the use of reducing washers?
George Little
Workgear for Electricians
#95561 09/21/05 05:37 PM
UL White Book
OUTLET BUSHINGS AND FITTINGS (QCRV)
GROUNDING
Metal reducing washers are considered suitable for grounding for use in
circuits over and under 250 V and where installed in accordance with
ANSI/NFPA 70, ‘‘National Electrical Code.’’
That's all I have except they make big holes small. [Linked Image]
#95562 09/21/05 06:01 PM
Thanks Bob- That's what I needed.
George Little
#95563 09/22/05 07:29 AM
That information really makes me question the technical expertise of UL.
Don
#95564 09/22/05 09:09 AM
Don I think the problem is the difference between test conditions and real life.
I have no doubt you or I could make reducing washers carry fault current if we used a wire brush to remove all paint from the enclosure and tightened the lock nuts decently.
However I know I see reducing washers all the time that are up against paint and loose.
I think an inspector could cite 250.12 Clean Surfaces almost every time.
Personally I dislike everything about reducing washers.
#95565 09/22/05 09:30 AM
I discussed this matter with the UL representative of CMP 5 (Article 250). He was surprised as well, but looking at the listing standard, it appears as though under test conditions reducing washers that are listed are capable of carrying a tremendous amount of fault current. I don't recall the exat test now, but it was several thousand amps for a substantial duration.
Ryan Jackson,
Salt Lake City
#95566 09/22/05 11:45 AM
I'm sorry, but if the test conditions do not represent a real world installation, the results are worthless.
Don
#95567 09/22/05 02:22 PM
I vote with Bob. Reducing washers keep the connector from falling out but I would use a bonding nut if I wanted to make a secure grounding connection.
#95568 09/22/05 07:27 PM
Reducers -- gotta hate 'em....
Every time I see them it's a hack job.
I particularly dislike reducers used at NEMA3R disconnects where the installer is shrinking back from a 1 inch KO goof.
Tesla
#95569 09/22/05 08:48 PM
I hate RE plates. I would rather screw a plate in the can and make sure there is a ground wire. I have had inspectors fail an installation; he wanted reducing washers; I had bolted a cover plate to the top of the box and had a grounding bushing and ground wire in the EMT. My way was better and I proved it to him with a megger. He made me change it to pass inspection. Still scratching my head Rod.
