0 members (), 1,041 guests, and 15 robots.
Page 9 of 9 1 2 3 4 5 6 7 8 9
Thanks around here if it is hard wired is has to be in for final but if it is cord and plug the plug is inspected, not the appliance. Rod
Workgear for Electricians
WOW... The NEC is taking on a new structure..
Let me ask this to Joe...
When did the NEC start jumping out of the wall?? I thought that was UL domain?
F
Sierra:
I noticed some said they can't check a house with-out power to get a final. Try hooking a Portable Gen to it. Its quick and easy, and when you leave the job you kknow you will not have to return.
Rob
It is unlawfull to energize any circuit prior to a pre-power inspection.
Finable up to 10,000 dollars.
Don't believe me? Ask Terry's electric who was fined on multiple circumenstances and fired few leadmen and thier helpers.
It shall be unlawful for any person to use any electrical current in or through any wiring apparatus or fixtures for light, heat, or power in or on any building or structure, until the same shall have been inspected and approved by the county administrator, and the certificate hereinafter provided for shall have been issued therefor.
(Ord. No. 71-4, ยง 1)
[This message has been edited by foestauf (edited 08-24-2005).]
