0 members (), 408 guests, and 18 robots.
#92506 03/19/05 03:43 PM
JOTAEME Offline OP
I need to size a fuse (in air swicht) to protect underground line 34.5kv 4/0 cu xlpe, which is connected of air line. This underground line feed a transformer 1000 kva 34.5kv
Jose Manuel
#92507 03/20/05 12:20 AM
F
this matter better have POCO help you with this one because there are few reguations you have to deal with this high voltage there
#92508 03/20/05 10:59 AM
Air switches don't use fuses, if your talking about 3-gang operated.
What style of fused switch are you using?
