ShoutChat Box
Low voltage fuses,where should they fit?
by dsk - 01/19/20 11:31 AM
ID strange fuses. never seen...
by dsk - 01/19/20 11:22 AM
diazed fuses
by djk - 01/18/20 05:10 PM
GFCI receptacle in kitchen
by gfretwell - 01/17/20 11:43 AM
15a. Switch on 20a. Circuit
by gfretwell - 01/17/20 11:33 AM
FPE in Germany pt.2
FPE Breaker panel in germany
1 registered members (Scott35), 28 guests, and 6 spiders.
15/20amp Recepts #90996 12/21/04 01:09 AM
aldav53 Offline OP
Old subject probably but can 15 amp recepticles be used on 20 amp circuits like a kitchen circuit.
I believe 20a recepts are usually used in a dedicated circuit, single or duplex.
15 amp GFI's say they can be used with a 20a feed thru circuit.
2017 / 2014 NEC & Related Books and Study Guides
Re: 15/20amp Recepts #90997 12/21/04 01:30 AM
Norstarr Offline
53, A duplex receptacle rated 15 amps can be used on a 20 amp circuit such as in a laundry room for the appliance circuit. You can not use a single 15 amp receptacle on a 20 amp circuit though. It must be rated 20 amp. All duplex receptacles in a kitchen, including the GFI's can be rated 15 amp. Hope this helps.
Ron
Re: 15/20amp Recepts #90998 12/21/04 02:39 AM
SolarPowered Offline
Also, a duplex receptacle counts as two receptacles for the purposes of this discussion, so it is OK to have a single, 15 amp, duplex receptacle on a 20 amp circuit.
Re: 15/20amp Recepts #90999 12/21/04 09:06 AM
Ryan_J Offline
See 210.21 and 210.24
Ryan Jackson,
Salt Lake City
Re: 15/20amp Recepts #91000 12/21/04 03:27 PM
DougW Offline
You can always have a smaller (ampacity) receptacle on a larger(ampacity) circuit, but you can't have a larger (ampacity) receptacle on a smaller(ampacity) circuit.
Re: 15/20amp Recepts #91001 12/21/04 03:40 PM
Norstarr Offline
DougW, Says who? I think you are quite wrong about that. Maybe if you explain in a little bit more detail it will make sense. According to your statement I can put a 20A 230 volt 3 phase TL receptacle on a 30 Amp 230 volt 3 phase circuit. No way. I'm sure you just used the wrong wording.
Ron
Re: 15/20amp Recepts #91002 12/21/04 03:46 PM
iwire Offline
Ron actually you can put a single receptacle of higher ampacity then the circuit it is connected to. [Linked Image]
Re: 15/20amp Recepts #91003 12/21/04 05:15 PM
George Little Offline
Mr. IWIRE, I am looking for an example where you'd put a higher rated single receptacle on a lower rated individual branch circuit and I'm not finding any. Except for the exceptions in 210.21(B)(1). And I'm not sure that's even an argument in your favor. Please educate me [Linked Image]
George Little
Re: 15/20amp Recepts #91004 12/21/04 05:47 PM
iwire Offline
George that is twice today I have been called Mr.
Please call me Bob [Linked Image]
First I did not say it was a great idea but lets look some of 210.21(B)
210.21(B) Receptacles.
(1) Single Receptacle on an Individual Branch Circuit. A single receptacle installed on an individual branch circuit shall have an ampere rating not less than that of the branch circuit.
Notice they did not say the same rating as the branch circuit or the values in Table 210.21(B)(3).
Now
210.21(B)(3) Receptacle Ratings. Where connected to a branch circuit supplying two or more receptacles or outlets, receptacle ratings shall conform to the values listed in Table 210.21(B)(3), or where larger than 50 amperes, the receptacle rating shall not be less than the branch-circuit rating.
IMO it is clear the requirements for single receptacles have nothing to do with Table 210.21(B)(3).
IMO single receptacles and multiple receptacles rated over 50 amps may be supplied with branch circuits rated lower than the receptacle.
I would have to ask what code section prohibits using a single 30 amp receptacle on a 15 amp circuit.
An engineer once wrote in asking if he could feed a 200 amp pin and sleeve receptacle with a 90 amp branch circuit.
No one could find a code section preventing that.
Bob
[This message has been edited by iwire (edited 12-21-2004).]
Re: 15/20amp Recepts #91005 12/21/04 06:41 PM
That does actually make sense. A 200 amp receptacle protected by 90 amp fusing will be safe. The reverse would not be--a 90 amp receptacle protected by 200 amp fusing is in danger of being overloaded.
I think that the confusion that arises comes from the concept that a 200 amp load is going to be plugged into a 200 amp receptacle. When you're dealing with plugs and receptacles in excess of 20 amps, that doesn't necessarily follow. The cord, plug and receptacle are normally often selected at the time of installation; they need to be sufficient for the load, but there is no danger in having them too big.
The fusing is normally selected specifically for the load, so there's not really an issue with the receptacle and fusing having different values.
At 20 amps and below, the situation tends to be different. Specifically, if a load is supplied with a cord with a 20 amp plug, it almost certainly draws more current than can legally be supplied by a 15 amp circuit. And 15 and 20 amp circuits are pretty much generic--you find an existing receptacle in the wall, and plug into it. So, if one were to put a 20 amp receptacle on a 15 amp circuit, there is more of a danger that someone will plug in a load that needs a 20 amp circuit.
[This message has been edited by SolarPowered (edited 12-21-2004).]
2020 National Electrical Code
Code (NEC)
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Vlado
Vlado
Croatia
Show All Member Profiles
Trumpy 12
dsk 5
262,411 Are you busy
197,537 Re: Forum
186,545 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
