0 members (), 88 guests, and 14 robots.
#87910 04/29/04 10:10 PM
i can`t find any code article on concentric ko`s that says i need a bonding bushing,other than service equipment.do i need a bonding bushing with a feeder to a panel if the conduit is being used as the equipment grounding conductor?what if i have a seperate ground wire ?any help would be appreciated.
Workgear for Electricians
#87911 04/29/04 10:11 PM
I'm sorry JMelectric. I should have at least said welcome to the forum. My bad.
Anyway, welcome to the forum. Take a look at 250.97 which addresses over 250V systems very clearly, then see 250.96 which addresses under 250V systems very not so clearly [Linked Image]
[This message has been edited by Ryan_J (edited 04-29-2004).]
Ryan Jackson,
Salt Lake City
#87912 04/29/04 10:38 PM
a little gray but after reading it a few times it makes sense ..thanks
