0 members (), 166 guests, and 8 robots.
Page 4 of 4 1 2 3 4
#87265 07/10/05 05:50 PM
e57 Offline
So has anyone else figured out a method for more than two locations, or a four-way? I am a little hung-over from a wedding last night, and just can not grasp the concept.
That, and how would any other than Maestro dimmers work on this?
And does this bear any relationship to the "Hollywood" 3-way?
#87266 07/12/05 04:50 PM
Whenever I wire for a 3-way, or 4-way lighting set-up, I always bring the feed and switch leg to the same box so at the end of switching it'll be a dead end. Doing it this will simplify any troubleshooting that needs to be done later.
Of course, sometimes because of box fill it can't always be done this way. If that's the case, I feed at the light box and bring down (2) 3-wire dead ends to each switch location.
As far as I know there are (4) ways to wire a 3-way switch design.
#87267 07/12/05 09:37 PM
Another problem with the coast system is that you can't add a 4-way switch without redoing the whole thing. Or at least I can't figure out a way to do it.
I have. You can insert one in the travelers in the usual way, as long as it's done at either end, i.e., between the lamps and either (or both) of the 3-ways.
If you place a 4-way between the lamps, then one will stay on all the time with the 4-way in one position.
Larry Fine
Fine Electric Co.
fineelectricco.com
#87268 07/12/05 10:19 PM
Ah, you're a wise man Larry, I spent way too much time trying to figure out a way to do it [Linked Image]
Page 4 of 4 1 2 3 4
