162
NAME THE TYPE AND USE OF THESE FITTINGS:
1.MC connector,..can also be used w/ AC cable 2.AC/MC "snap-in" connector..no lock nut 3."Flex" connector..for Greenfield ..3/4" and above.. 4.Steel AC connector,to be used only on STEEL AC cable. 5.Set screw type EMT connector 6.Duplex AC/MC "snap-in" connector 7.Inside thread Greenfield connector,..seen on lighting whips and in recessed lighting whips...
#5's a greenfield connector. The setscrew's angled to keep the greenfield from pulling out.
[This message has been edited by ga.sparky56 (edited 12-21-2003).]
never have seen #5 there, i would think that one could crush flex easy with a ss...
The set screw flex connector in #5 is the most common one I see. The inner ring suburbs here that were built under the local "all metal" code have this connector on 99% of the flex run.
The screw tightens down into a valley between the corrugations of the flex, forming a burr that prevents the flex from sliding out.
Al Hildenbrand
I'd never seen that type of Greenfield connector...from the pic, it looked like an EMT conn. ....??? oops!!!.... is that a Bridgeport???
[This message has been edited by Attic Rat (edited 12-21-2003).]
..Do you still have to use an "anti-short" bushing with #7..? and if so,...how???
I would think that you don't need a redhead on #7 because there is no sharp edge, the connector threads inside the greenfield.
I use a lot of #3 for 1/2" greenfield. I have #3, 5 and 7 on my truck in both 1/2" and 3/4" now. It just depends on which supply house I got greenfield connectors from. You do not need a red hat with any of 3,5,7.
ed
