I have seen 'clock' outlets used behind a lighted hutch so that the furniture could go closer to the wall.
My favorite Chinese restaurant (looks like an old dingy diner) in Midtown (near Pennsylvania Station) has these pictures with little lights clamped on top of the frame.
Behind the canvases are clock receptacles so that the lamps can be neatly plugged in without having the plug bulge out into the frame.
The clock receptacles have to beREALLY OLD though. They are two-pin sockets!!
I've always seen the three-pin versions in existing buildings where the old electric clocks have been removed.
Not much use nowadays, considering that a lot of "office clocks" are now those cheap battery types you get from the discount/variety stores. Then just use the hook in the wall palte to hang the battery clock.
