0 members (), 930 guests, and 11 robots.
Redsy Offline OP
A customer wants 2 hi-hats over a tub. I have done this before and installed a shower trim. However, she would like 4" size. I can't fing a 4" shower trim, but I also think they may not be necessary. Is the area over a tub considered a damp location, or is this a call for the AHJ?
Workgear for Electricians
Redsy, I went through this with my AHJ a few months ago. He said i needed a shower trim and i said i dont think that a ceiling above a tub is a wet location in the eyes of the NEC. He read the definition of a wet/damp location in art 100 and agreed with me. Most open trims are listed for damp locations and thats what we use over a tub.
Redsy Offline OP
Thanks for the quick input, arsegee.
I am concerned that if we install 4" cans and he flags the final, I'll have to cut out the fixtures to install 6".
I will discuss it first.
Redsy
Juno makes a shower trim for their IC-1 housing that uses a 50PAR20. You could install what ever trim style the owner wants and if the inspector give you a hard time change the trim to the shower trims. I don't remember the part number right now but can post it for you later today. Juno also makes a 6" shower trim for their IC-2 housing that uses a 75PAR38 lamp.
Curt
Curt Swartz
GTE Offline
I have used open bulb recess over tubs with no problem as long as there isn't a shower.
For anyone that's interested here is a link to Juno's 4" Housings and trims. The shower trim that uses a 50PAR20 is the 12W-WH or 12W-SC http://www.junolighting.com/pdf/spec/G3_1_0.pdf
Curt Swartz
Redsy Offline OP
Thanks a lot Curt.
I couldn't find 4" showere trims so far.
I appreciate the help.
Hi, thought I would add my two cents. If the bulb exploded, would you want to be under it in the tub? Just a thought.
GTE Offline
Richard,
If a bulb exploded anywhere, would you want to be under it? Just a thought.
