0 members (), 657 guests, and 30 robots.
#78428 09/23/01 12:38 PM
DUBLIN Offline OP
When installing lo/vo lighting in a residential dwelling controlled by a wall switch/dimmer, where does your local inspector allow the electronic transformer to be installed? In a junction box, outside the junction box, loose? Where talking about line voltage and lo-voltage together (input 120V 50-60Hz 0.5A, output 12V 20KHz, loads 50W-150W). Most inspector here at least agree that no installation complies 100%.
Any thoughts?
| )ubli| |
Workgear for Electricians
#78429 09/23/01 02:59 PM
Does anyone make a transformer that mounts on the 6-32 screws with line connections on backside? This way the 120 volt connections could be contained in the box.
#78430 09/23/01 05:29 PM
DUBLIN Offline OP
Yes most magnetic types are configured like you mentioned (either held by screws or treaded for a lock-nut),but i'm referring to the electronic type, haven't seen one of that design yet.
[This message has been edited by DUBLIN (edited 09-23-2001).]
| )ubli| |
#78431 09/24/01 07:31 PM
Anonymous
Unregistered
Loose is not a good choice. And it cannot be outside the box with 120 V conductors exposed.
There is surely a way to strap it to something or you can drill and tap its mounting bracket for screws.
