0 members (), 392 guests, and 30 robots.
#77662 07/09/01 01:00 PM
Posted for JP
Is there a new regulation/standard that requires businesses to replace the old armored caps, or attachment plugs, with the newer plastic type? Cannot find anything in regulations.
Thanks,
JP
#77663 07/11/01 03:19 AM
See Section 410-56(g)
"(g) Attachment Plugs. All 15- and 20-ampere attachment plugs and connectors shall be constructed so that there are no exposed current-carrying parts except the prongs, blades, or pins.
The cover for wire terminations shall be a part, which is essential for the operation of an attachment plug or connector (dead-front construction).
#77664 07/11/01 05:02 AM
80-9(b) in 2002, Existing Installations
basically, if the AHJ determines it's a hazard it goes...
#77665 07/11/01 05:04 AM
80-9(b) in 2002. Existing Installations.
Basicaly, if the AHJ determines it's a hazard, it hits the road...
