0 members (), 1,135 guests, and 9 robots.
#75230 02/18/07 01:56 PM
What does the code say about how close the panel is to a gas line or gas meter?
#75231 02/18/07 02:03 PM
The code book doesn't mention anything about being to close to a gas line. You must have 30" inches total clearence to the sides. Read article 408.
Jesus may have been a capenter,but God was an electrician.Genesis1:3
#75232 02/18/07 02:31 PM
Better that you read 110.26.
That's where the info re: clearance around panels is located
#75233 02/18/07 05:11 PM
Doesn't the utility company have a say in the matter as well?
I was told years and years ago to stay at least 36" away from the gas meter when mouting an electrical panel.
#75234 02/18/07 11:52 PM
It depends on the local utility.
Edward
#75235 02/19/07 02:08 AM
My local Propane company won't set a tank within 10' of almost anything but they don't seem to care about pipes, valves, regulators or gas equipment
#75236 02/20/07 10:16 AM
Z
I'm with Niko on this one. IT's all up to the utilities in your area.
My advise is NEVER proceed with a build without consulting every utility before hand. You could easily lose your butt if suddenly a utility comes in and informs you that they will not hook up their service because of clearences - especially if the foundation has already been poured over conduits and gas and water lines. The GC and engineer should have all this worked out, but it's never a bad idea to make sure.
And yes, I have been there because of a lazy GC.
