0 members (), 1,107 guests, and 15 robots.
Page 3 of 3 1 2 3
#73932 01/08/07 07:51 AM
Pot grower's myth:
"If I run my lights at 240v it will cost less than at 120v right?"
#73933 01/08/07 10:06 AM
Why is balancing better at 240?? If I run 2 120 v circuits on different phases, how is that any different than a single 240v circuit??
#73934 01/08/07 11:25 AM
I had made my statement about meters based upon information I had been told by an old timer many years ago and I never actually confirmed it. He insisted that we always keep our load evenly distributed in the panel, which always makes perfect sense to me. HIS logic however was that if one leg has say, 60 amps running on it and 35 on the other that the meter would register the higher leg and bill that usage. Like I said, I never knew if this was true or if he was pulling my leg. I have just always done this since then.
---Ed---
#73935 01/08/07 01:40 PM
Bob,
That is why I said "will be the same for the same load"
In other words if the wire size and current remain unchanged
O.K., I'm with you now. Same load in amperes, not in watts. [Linked Image]
Page 3 of 3 1 2 3
