AE-Gifts, Affordable Everyday
0 members (), 723 guests, and 12 robots.
#73061 12/29/06 12:55 PM
wendel Offline OP
If you go to this page: http://www-public.tnb.com/ and look at the upper right hand tabs you'll see Distributor. Click that tab and in the next screen use the second way (T&B Distributor Listing) to get distributors within your zip.
#73062 12/29/06 01:41 PM
wendel Offline OP
Update. None of the distributors carry the T&B wire nuts. I had to do a special order for the 335C (8 to 18 gauge). The smallest quantity seems to be the cards (6 per card) with a 20 card minimum order @ ~1.30 per card.
#73063 12/29/06 01:50 PM
Wendel are these connectors listed for wet locations?
#73064 12/29/06 03:13 PM
wendel Offline OP
These are connectors with copper coated springs inside. They are the best I have found when dealing against outdoor corrosion. http://www-public.tnb.com/contractor/docs/marrette.pdf
#73065 12/29/06 04:55 PM
What I am trying to say is wirenuts may not be the proper connector for the location regardless of the internal material.
#73066 12/29/06 09:10 PM
wendel Offline OP
I can only say every connection I have ever come across is a steel spring wirenut that's usually totally rusted. My goal is to improve on what seems to be accepted practice of using wire nuts for low voltage outdoor circuits.
#73067 12/29/06 10:23 PM
Ideal sells 'set screw wire connectors'. These have a brass sleeve with a brass set screw on the side. You insert the wires into the sleeve, and tighten the set screw. Then the whole thing screws into a plastic cap.
Yeah, I'm familiar with those, used them alot in class1 div 1 locations...
Luke Clarke
Electrical Planner for TVA.
#73068 12/30/06 03:30 AM
e57 Offline
Are these for direct burial? Even in salty air theses do great. http://www.kinginnovation.com/pro-dryconn.html
Although I'm not fond of the comparitively weak plastic cap for the nut - as it is essentiallty just a container of silicone with a spring connector in it, and if a brute like me, they can crush in your hand... But they do work well for the purpose. For the longest time they were the only patent holders for this type of application. Now a few others are making them too. Havent use these yet though... http://www.idealindustries.com/wt/TwistOnWireConnectors.nsf
#73069 12/30/06 12:52 PM
I've used the King wirenuts for repairs in underground Christy boxes on parking lot lights , and they've held up really well [Linked Image]
