0 members (), 1,055 guests, and 16 robots.
#71008 10/19/06 10:53 PM
Niko Offline OP
Who would you use or call to monitor and record power consumption?
I looked in the yellow pages and can not come up with anyhting.
Thanks.
edward
#71009 10/20/06 01:25 AM
Hialiah Meter sells refurbed watt hour meters pretty cheap, $20 or less.
It's hard to beat what the PoCo used to bill you.
#71010 10/20/06 02:38 AM
Your best bet is to get a secondhand POCO meter as already suggested and use it as a check meter on the circuit concerned.
Also you can look on Ebay where they are sold for around US $15. + postage.
#71011 10/20/06 04:03 AM
e57 Offline
Power consumption? KwHours? Get the dreaded E-mon D-mon. Landlords love 'em, tenents loath them..... Use tamper-proof screws. [Linked Image]
Demand/quality monitoring, you can do short term rental of logging units, or purchase/lease for long term. You'll have call around in your area, but there are those on the internet.
#71012 10/20/06 09:32 AM
Niko Offline OP
Thank you for your input.
Edward
#71013 10/20/06 12:05 PM
http://www.hialeahmeter.com/spwm.html
$16.45 but you will need to come up with an old meter base
#71014 10/21/06 11:45 AM
If this is a commercial setting, you need to also figure in the demand as this can be a significant part of the billing. The meters usually sense the largest demand over a 15 min. period and are reset by the meter reader each month. Then the demand clause of the rate structure tells you how much you pay. There is usually something called a "ratchet clause" so that wintertime demand gets close to July & Aug. HVAC equipment demand.
