Electricians revenge
1 members (Scott35), 178 guests, and 13 robots.
#66530 06/06/06 08:51 PM
Jim M Offline OP
Just received a flyer for one of these and was womdering if anyone had any experience with them. The are one sale for $50 off the normal price of $319.
If you have one do you use it much, and do you charge for a diagnostic service?
http://www.tasco-usa.com/ins2.htm
#66531 06/06/06 09:22 PM
TEST...
* WIRING ABILITY TO HANDLE 10, 15 OR 20 AMP LOADS TO CODE STANDARDS
* ALL SPLICES AND CONNECTIONS
* LINE VOLTAGE UNDER LOAD
* WIRING CONFIGURATION
* OUTLET GROUND
* GROUND LINE IMPEDANCE
* GFI FOR PROPER OPERATION
How does it "test....all splices and connections"?
~~ CELTIC ~~
...-= NJ =-...
#66532 06/07/06 07:59 AM
I have an Ideal tester that performs almost all these functions. I use it daily...I always test my work. I also go through a whole house testing all accessible outlets & GFCIs. I charge for all services except warranty work.
Dave
