835
20
Hi to everybody and hope that you are having a great memorial day weekend.My question is what name brand and type of crimpers you guys have for your residential service connection?
Greenlee Gator Pro Eccx, with H-tap die...
Dnk..
Posts: 7,413 Likes: 9
OK, another 'Jersey Guy' pops up. WELCOME to the ECN forums.
I have a Penn dieless crimper. Hydraulic, no dies, with Illsco. or generic crimps.
I'm with Dnk. Same Greenlee Gator Pro .....
It works great and has for a long time now.
I have a set of Blackburns with curved hickory handles, 5/8 fixed nose die and die cavity for my O, D and 840 diesets. Those are the dies I use the most. A friend has a complete set I borrow from if I need something odd. The tool is not too expensive @ around $300.00 but the diesets are better than $50.00 a set. It can get real pricey if you need all of them. A dieless hydraulic would probably be more cost effective. The Greenlee Gator is awesome. One-handed crimping or crimping in a narrow ditch is a breeze. Too expensive for me no more than I need to crimp H-Taps.
We never need them. The lugs are either lay-in, or the POCO does the crimping.
We also can't land the driven GEC in the meter base, which I think sucks.
[This message has been edited by Larry Fine (edited 05-27-2006).]
Posts: 5,485 Likes: 4
Similar here, Larry- we are required to use PoCo supplied parallel groove connectors, which tighten with a wrench.
Though, on jobs where I do use crimp connectors, I use the crimper provided by the parts house.
[This message has been edited by renosteinke (edited 05-27-2006).]
HCE727
Delaware County, PA, USA
