0 members (), 1,002 guests, and 12 robots.
#65414 05/02/06 06:08 PM
Anyone that does old-work residential has probably come across the same thing- light fixture somewhere wasn't putting out enough light, so someone puts in a "better" 75-100 watt light bulb in a 60-watt max fixture, eventually it cooks the fixture, and the plaster around the fixture, and the insulation on the wires. So I was talking with my dad today and he came up with the idea of something like the S-type fuse adaptors in the lights that would make it so that only a special 60 or 40 watt light bulb could be installed. Or even have a thermal coupling installable in old fixtures, I think it'd be a good idea, landlords could put it in all their rental properties, cut down on energy usage and wire/plaster damage.
what do you think?
#65415 05/02/06 06:30 PM
It would be easier and cheaper to simply install a $10 2-bulb luminaire which will accept larger wattage bulbs safely, and/or paint the ceiling white.
Earl
#65416 05/02/06 07:42 PM
They did something along those lines at the local "cockroach motel"... Only what they did was convert all the fixtures to " tamperproof compact fluorescent"... Whereby the only way to get these lamps out is with a special tool.. Therefore only maintenance can change the lamps, and at the same time the building's power consumption has dropped quite a bit... ( Tenants electricty is included in rent, no individual metering).
