1,382
I would like that idea if my place were the "Palace of the electric motor".. OR it was a big place... ( In my dreams) ![[Linked Image]](https://www.electrical-contractor.net/ubb/biggrin.gif) .. There is one such house not far from here that requires 120 / 208 three phase because its that big... 18 car garage to start need I say more? ![[Linked Image]](https://www.electrical-contractor.net/ubb/biggrin.gif)
Many larger Apt. buildings (Some of which I have done) have 3 phase 208 wye as a service for mixed commercial/residential, or even all residential if large enough. But the resi units only get two of three phases at the panels. All common areas and commercial units get 3 phase. A guide to rules for such are at the last 2 pages of this doc. PGE doc Edited to shrink page [This message has been edited by Roger (edited 01-21-2006).]
Come on down to Fairfield county, CT. I could show you several houses with 1200 and even 1600 amp 3-phase service!
Bob,
1HP mechanical output = 746W mechanical output.
You need to account for the effciency when converting from mechanical output to electrical input watts.
Many people mis-interpret the smaller ampacity requirements of a 3-phase motors as meaning they consume less power. The real cost savings of 3-phase is in the reduced "size" of the distribution system components.
You need to account for the efficiency when converting from mechanical output to electrical input watts. Yes and this applies to single phase as well as 3 phase. You can by high efficiency motors or cheap ones. My point was the same as your point that going three phase does not necessarily mean energy savings any more than a 480 motor saves over the same HP (and efficiency) motor in 208 volt.
Of course, Mr. "I've got more dollars than sense" wanted us, the POCO, to pay for it. Hmm..... The PoCo provided the 3-ph supply he asked for, then it's supposedly their fault when the A/C guy doesn't bother to check and find out that's it's a high-leg arrangement. I'm sure the judge would go for that argument. ![[Linked Image]](https://www.electrical-contractor.net/ubb/biggrin.gif)
I agree that motor efficiency must be taken into account for 3 phase versus single phase.
Here is a quote from Reliance's web site on motor efficiency:
THREE PHASE POWER & SINGLE PHASE POWER 3 phase power is typically 150% more efficient than single phase in the same power range. In a single phase unit the power falls to zero three times during each cycle, in 3 phase it never drops to zero. The power delivered to the load is the same at any instant.
[This message has been edited by sandpiper (edited 01-22-2006).]
It gets very tricky. In a single phase unit the power falls to zero three times during each cycle, in 3 phase it never drops to zero. Wouldn't that be 2 times per cycle? Regardless you are not paying for electricity when it falls to zero. A 5 HP motor provides 5 HP single or 3 phase. What you do notice is a significant size difference between a 5 HP single and a 5 HP 3 phase.
We are comparing single-phase and three-phase induction motors, of course, not brush motors. Once running, the operating efficiency between the two types of ind. motor is of little actual significance to a home user, as you can't 'save on wire' if you use a single phase + a neutral at the point of use, and how many domestic three-phase food blenders, wash machines, hair driers, dish-washers, 'fridges etc. are on the market? The question was '3ph for domestic use' and all in all I still can't see any valid reason for it. If you want to save a few $$$s on a bit of wire, buy 230v kit and have done with it. Actually, I'd bet that dc-inverter brushless motors [no commutator; a permanent magnet armature; a chip and solid state switching to the field windings ] will sweep all these 'ancient' motors away in the next few years, for their starting torque, efficiency, small size and variable speed qualities.
If you have an 80% efficient single phase motor, there is no way that you will be able to replace it with a three phase motor that is 150% more efficient. -Jon
Shinnston, WV USA
