Photos of the Week:
Tiled Backsplash
Tiled Backsplash Devices
Random Gallery Image:
0 members (), 590 guests, and 16 robots.
#58573 11/12/05 08:52 PM
Cinner Offline OP
I am doing a 40 amp 2 pole gfci breaker install for a hot tub that needs only 240v. The gfci breaker has 2 neutral terminals which I understand, but in this install there is no neutral needed. Will the gfci monitor an imbalance b/w the 2 hots?
If the tub manufacturer states a grounded conductor(neutral) is not required, connect the line side white wire on the breaker to the neutral bus and leave the load side neutral terminal empty. The breaker will work as designed.
steve
Steve
Tools for Electricians
RH1
RH1
California
363,487 Are you busy
286,303 Re: Forum
264,840 Need opinion
