AE-Gifts, Affordable Everyday
0 members (), 284 guests, and 20 robots.
#580 02/11/01 01:14 AM
One thing I would like to get is a laser level. That looks like it could be a very useful thing. One of these days...
#581 02/11/01 12:42 PM
Bill;
the last 4' gotta get out the sledge....i'm still in the R&D process with this one. [Linked Image]
The code says "straight " in first, so one day , up on my ladder , i take a swing and miss, and hit the ladder.
Luckily, no one was watching, or i would have had to explain that doing a faceplant in the mud was part of my special technique.
#582 02/11/01 01:51 PM
Take an old spline bit, cut it off and weld a cup on the end. Put it in the ol' Hilti and presto... no more busted knuckles...
I've heard stories of guys driving ground rods here in the limestone region, start out driving them straight in and have the other end pop up out of the ground several feet away!
-Virgil
5 Star Inspections
Member IAEI
#583 02/11/01 06:07 PM
66'
That Hilti is the best deal...i think they have a bit for rods, either that or there is something meant for another application that can do the job.. [Linked Image]
I just need to choke up the scratch....i got a little porter cable for now..
#584 02/11/01 06:11 PM
How about meggers? i have this funky little CEU one and would like to upgrade....
any suggestions?
#585 02/11/01 06:15 PM
Bill,
i don't have a laser level, but a friend of mine does.
Many useful applications, and fun too, he drives the cat nuts with it!
#586 02/11/01 07:55 PM
Tom Offline
Sparky,
Try this for installing rods- a gallon jug of water. Start your rod in a couple of inches, pull it out, fill hole with water, re-insert rod & jack it up & down by hand. When it starts to move with difficulty, pull it out, fill hole with water & repeat.
I never thought this method would work here in WV, but I've gotten them in up to 7 feet. Of course, soon as you hit a rock, out comes the sledge.
#587 02/11/01 08:02 PM
thanks Tom;
I'll try just about anything for driving rods......
#588 02/11/01 09:32 PM
I guess we're a bit spoiled here (LI - big ol' sand bar) sometimes can get it it 4 feet just by pushing down, I got a 5 lb Hammer and tap it, sometimes worry about losing it before I can get the wire on it. We do have rocky areas or clay, but mostly it's not a chore getting it in.
#589 02/11/01 10:16 PM
I have used the water method driving method but it only seems to work where the ground is soft. I use my hammer drill with a ground rod adapter
