1 members (Admin), 406 guests, and 12 robots.
#57783 10/21/05 08:53 PM
A watt is I x I x R = I squared time R.
A wattamp is I x I x R x I = I cubed times R, or (I**3)*R. This quantity is often used to rate hoy tubs.
#57784 10/21/05 09:45 PM
Given... 4.0kwa or 4000 watt amps
249 volts as per subject title
4000 watt/amps divided by 249 volts is 16.064.
a watt amp would be amps times volts times amps so...
16.064x249x16.064=64254.97 or just under 65 kvaa at 249 volts.
I recomend using atleast 4/0 to handle that load.
#57785 10/21/05 10:04 PM
Doh!! [Linked Image]
Stupid should be painful.
#57786 10/21/05 10:18 PM
Here's how I wired my hot tub:
1) bought the tub
2) Opened a beer
3) watched electrician work :-)
Seriously, though....You want someone to use pipe, and not Romex, SE, etc.
You want a disconnect where you can find it.
If outside, you want the wires in pipe, buried DEEP.
You want everything GFI protected....well before it gets to the tub.
Finally, you want to keep ALL other electric stuff well away from the tub. Assume that everything you want to put within, say, 10 ft. of the tub is a bad idea, and don't do it. No paddle fan, no stereo, no yard lights, etc.
#57787 10/22/05 11:20 AM
A hen weighs approximately a bicyle because a vest has no sleeves.
You can identify one easily because they are a kind of brown redish.
#57788 10/22/05 01:00 PM
This sounds like a discussion for the hoi polloi...
#57789 10/23/05 12:41 AM
Redsy, do you walk to work or carry your lunch?
Larry Fine
Fine Electric Co.
fineelectricco.com
#57790 10/23/05 08:44 AM
Larry,
I drive my lunch to work.
Have you ever eaten a brown redish?
#57791 10/23/05 10:35 AM
Boy you guys are a bunch of comedians! [Linked Image] I am surprised nobody said the obvious reply.
How do you wire a hot tub? Very Carefully!
#57792 10/23/05 04:57 PM
What's a lunch??
Not in the code book, are they required?
Dnk....
