Electricians revenge
1 members (Scott35), 211 guests, and 11 robots.
I often have to remind one of my guys to chack line-to-line as well as line-to-neutral when troubleshooting services.
Larry Fine
Fine Electric Co.
fineelectricco.com
Wnen you are checking a switch or fuse, check across it. You should see zero if it is closed and full circuit voltage if it is open, assuming down stream load is connected.
NJI Offline OP
hello, long couple of days here..havn't had the chance to get back to you
yes...the feeding through the element was the result of my reading voltage. re-instaled. workes perfectly. sometimes you just need a second opinion from time to time to help process. When you work alone sometimes the hour get to you...the thought process gets kind of fogged thnks for the quick help!
I have worked as an apprentice and on to a journeyman in a general construction company. 90% of what I do is residential. I have an associats degree in electrical technology. I have started my own buisness this year and am with out the help of other electricians. this is why i find this site so helpful.
