0 members (), 957 guests, and 17 robots.
#50302 04/01/05 01:25 AM
e57 Offline
Please brows this, and ponder what is a hand here: http://www.essexep.com/electrical/products/building/pdfs/Type%20NM-B%20Color%20Coded%20(NM%20Sheathed%20Cable.pdf
THHN conductors in paper and PVC sheath. Remove this paper and PVC sheath, and you have THHN conductors and a bare ground, right? Why don't they just use the dual rated THHN/THWN stuff they also make?
[This message has been edited by e57 (edited 04-01-2005).]
#50303 04/01/05 02:17 AM
It's probably the paper that makes this dry only. That and NFPA
#50304 04/01/05 02:23 AM
e57 ---
If I read the data sheet right, you can get NM with no paper. It is still only rated dry.
#50305 04/01/05 12:17 PM
Then I guess we are stuck with what NFPA tells us. Proposals are still open for the 2008.
#50306 04/01/05 09:32 PM
e57 Offline
George-
"Why don't they just use the dual rated THHN/THWN stuff they also make?" It would make this situation much easier if they did.
