0 members (), 303 guests, and 10 robots.
#49798 03/17/05 09:22 PM
BigJohn Offline OP
I recently had to re-wire a three-way switch. What I found on arrival was that when the first 3-way was down, the second 3-way would turn the fixture on and off.
When the first 3-way was up, the fixture would come on and stay on regardless of the position of the second 3-way.
There was nothing unusual about the wiring: Feed at first switch; 12/3 carrying the neutral and two travelers to the fixture; neutral ties to the fixture; 12/3 continuing travelers to the second switch and carrying switched conductor back to fixture from second switch.
Both switches had cracked casings so I replaced them both without paying attention to how they had initially been wired, but afterwards got to thinking about it:
How is it possible to wire a switch so that it will not turn off a light? I can't come up with an answer, can you?
-John
#49799 03/17/05 09:44 PM
Hi,
There is only one way this can happen.
The switches WERE MISWIRED when you got there...unless the switch is damaged..
look at this: http://www.lowes.com/lkn?action=how... =RightNavFiles/rightNavHowTo#wiring1
Heres what you do..
find where the power comes in...AT THE SWITCH..SW 1..
find/identify the HOT/FEED conductor that goes to the light..this is the COMMON..
then identify two wires as travelers..make sure toi keep them on the same corresponding brass/white scres between the sw1 & sw2
the hot/feed (common)goes to the BLACK screw on one switch for the POWER IN.. SW 1
the supply (POWER OUT) to the LIGHT goes to the OTHER black screw (common) on the OTHER switch.. SW 2
connect the neutral at the light ONLY..and the feed from the sw 2 to the light..
do that and it has to work!
anything else and it wont work properly!
hope that helps..
good luck..
regards
greg
[This message has been edited by mustangelectric (edited 03-17-2005).]
#49800 03/17/05 09:57 PM
BigJohn Offline OP
Mustangelectric,
I appreciate your help, but you misunderstood my question: After I replaced the switches, everything worked properly, I was simply wondering how in the world the first yahoo managed to wire them so that the light couldn't be turned off from one of the switches.
-John
#49801 03/17/05 10:00 PM
Hi,
WHO KNOWS! I have seen this condition many times from home owners or someone else who meant well but once they took the wires apart they realized they did not know what wire went to what..
it was always a simple matter to swap a couple wires...charge them and get some glory!
Glad you fixed it!
thats my best guess!
-regards
greg
#49802 03/17/05 10:24 PM
e57 Offline
Hot - traveler reversed on power side of the circuit.
So... while on the subject. Heres a good 3-way puzzler. How do you make a 2 single pole 120v switches on 2 different services in the same building act as a 3-way for 2 seperate sets of lights? I just did this the other day.
#49803 03/17/05 10:38 PM
Hi,
e57: You said: "How do you make a 2 single pole 120v switches on 2 different services in the same building act as a 3-way for 2 seperate sets of lights? I just did this the other day."
first question..WHY?
ok i will take your bait!-
first we have four terminals to work with..they are all common...
take the hot in and go to one switch...from that same term....go to the other switch and term on that switch...
the two remaining terms run to the light.
i am not sure how you would do that with two seperate feeds...i gues L1 goes to one switch and L2 goes to the other switch then to the lights?
-regrds
greg
#49804 03/17/05 10:48 PM
Hi,
Heres another one for you to chew on:
How do you wire up a 2 pole three wire dryer?
-regards
greg
#49805 03/17/05 11:01 PM
Hi,
to tell you the answer I would have to draw a schematic of it for you all(its kind of complicated) ..but i dont know how to post an image..
how do you do that?
-regards
greg
#49806 03/17/05 11:20 PM
Hi,
If you cant figure out how to wire a 2 pole three wire dryer..
just use this schematic i made..
http://pg.photos.yahoo.com/ph/masterelectrician@sbcglobal.net/my_photos
it works everytime!
-regards
greg
[This message has been edited by mustangelectric (edited 03-18-2005).]
#49807 03/18/05 12:48 AM
Nice one greg [Linked Image]
ed
