0 members (), 392 guests, and 30 robots.
Page 3 of 3 1 2 3
#49322 03/06/05 12:35 PM
Redsy Offline OP
I guess I should back-up a bit.
The original problem is a faulted fixture on a 3-pole CB, which is causing the whole area to lose light.
I'd like to do this as simply and inexpensively as possible.
I'm wondering about retro-fitting fuse holders at each ballast.
BTW, the set-up consists of a 10 rectangular remote ballast enclosures, each of which houses ballasts for 2 fixtures. I've heard that there used to be dual-lamp M-V ballasts, but I don't know if these housings contain those, or 2 separate remote ballasts.
The problem is that I can't access the existing equipment without a lift and I don't want to rent a lift until I'm ready to solve the problem.
Energy savings aside, the only reason I thought about fixture replacement is that I don't know if I can retro-fit fuse holders. I'm having a hard time finding aftermarket fuse holders. But, if I can install them, that's what I'll do.
#49323 03/06/05 02:31 PM
Redsy, check out www.bussmann.com Look at panel mounted HPF fuse holders, or their HEG & HEY series of in line fuse holders. Both types take CC rated fuses 1/4 - 30 amp 600 volt ratings. You might be able to fit these fuse holders in the remote ballast enclosure.
Al
#49324 03/06/05 07:58 PM
Redsy Offline OP
Aye, aye captain!
Sorry, my kids have me watching "SpongeBob".
Anyway Al, Thanks for the link. I was on their website and couldn't find inline fuseholders.
A great help!
Page 3 of 3 1 2 3
