One power supply cable of a 250KW, 480V motor is grounded and will be replaced with a bit bigger cable due to its the only available cable in the warehouse. DOes the motor operate safely with the scenario.
In my own idea nothing would be a negative effect on the motor. Any adea what will be the effects?
