6-6-98 Somebody asked the question about the three switches in the basement and the light bulb in the attic. Here is the answer: RAY: You turn the first switch on. You leave it on for ten minutes. Why, you ask? You'll see in a minute. Then you turn it off and you turn the second switch on and you go upstairs.
This is an old puzzler from CarTalk.com with Tom and Ray, the tappit brothers. Look under puzzler and archives. These are pretty good. ~Peter
Bucketman You did no miss a thing. You are right on. The reason I asked this question was because there was some confusion on another forum regarding 240.3B and transformer secondary. Some felt that 500 kcm was the minimum size. However 240.20C requires the ampacity of the conductor to match the OC device.
[This message has been edited by Bob (edited 01-16-2005).]
Q:"Which of these Seperately Derived Systems (SDS) may use the OCPD on the Primary side to protect the Secondary side feeders - and why?"
A: (A) 240.(C)(1) & 450.3 (B)
I was thinking "A", "B" and "E" would qualify, as they all have a "Single" Secondary Output Voltage", whereas "C", "D" and "F" would nt qualify, as they have Multiwire Secondaries.
Scott35
