Electricians revenge
1 members (Scott35), 183 guests, and 10 robots.
JBD Offline
Yes, UL will use the phrase "not investigated" for that use, but that does not mean it is a "violation". It simply means that they have not tested the condition and it is up to the AHJ to decide if the application is accetable.
The AHJ always has final approval. UL Listing is only an aide/tool not an "end all".
What I have done for pool work is to buy a pressure treated 1 x 6 and screw it to the above ground portion of the post.
It looks nice and provides enough width for 2 parallel conduits with straps.
You don't get prior permission from an inspector for something that seems to be a common sense approach.
That's why you are in the spot you're in.
The mounting ears are not quite covered by the cedar post so we would be required to make a bracket large enough to be behind the mounting ears or put in screws at an angle to hit the cedar post. Instead we
You already knew the answer. It was fine until "Instead we"
I've had plenty of "good ideas" myself. My thoughts that they were good didn't necessarily mean that they were, and certainly didn't mean that others were required to share my opinion.
Neither NEC 90-4, nor 110-3(b) make mention that you can use your own version of common sense.
[This message has been edited by electure (edited 11-25-2004).]
'round these parts I have always heard an explanation similar to wa2ise's... the fear is that in the ungrounded box the screws would get hot and stay hot, or spark and create a fire hazard. I was always taught exposed screws in plastic boxes were no-no's but many inspectors will look the other way if it is an indoor application like a switch box placed in some odd wood-framing or when the customer wants a box mounted horizontally or some such thing, but outdoors & damp... I wouldn't expect to get away with it in CA.
Electure,
What?
