0 members (), 693 guests, and 9 robots.
Page 3 of 3 1 2 3
#4512 10/04/01 06:01 PM
Although this is generally true, it is not a requirement.
Some older panels have the breakers mounted vertically with the busses horizontal.
I haven't seen newer ones that way for awhile,tho.
#4513 10/04/01 06:48 PM
pauluk Offline OP
Just about all domestic panels here have a horizontal busbar (usually at the bottom) and breakers or plug-in fuse carriers mounted vertically in a single row (only one hot leg remember).
Three-phase is generally two vertical rows of breakers mounted sideways with a main switch at the bottom.
#4514 10/05/01 06:43 PM
Anonymous
Unregistered
1999 NEC 240-33?
#4515 10/06/01 09:15 PM
240-33 says only that the enclosure must be mounted vertically if possible.
(I actually did see a service mounted sideways one time)
#4516 10/06/01 09:21 PM
Anonymous
Unregistered
I hadn't thought of that way.
So does this just prohibit mounting it with the back against a floor, ceiling, and anything that isn't a vertical wall? But not which way the box itself has to be oriented?
#4517 10/07/01 08:34 AM
Another word for "box" is "enclosure."
Page 3 of 3 1 2 3
