0 members (), 533 guests, and 35 robots.
#44345 11/07/04 09:52 AM
Why not use a plastic old work box they a little bit bigger the the metal gem box. I am not a big fan of these and only use them for situations such as this, or to get more cubic inches.
Why wouldn't you want to use these? If you're using romex these boxes are much easier to use than a metal box and clips. I prefer the box made by P&S, but even the crappy Carlon Box is easier to use than a metal box.
[This message has been edited by Electric Eagle (edited 11-07-2004).]
#44346 11/07/04 11:54 AM
Old plaster is always an adventure.
One time I was changing out an outlet in a living room. Nothing difficult, I didn't even have to mess with the box....just change out the broken outlet.
I had barely gotten the plate off and just touched the outlet and a piece of plaster about 2' square slabs off the wall leaving a huge are of lathe exposed and spreads itself across this ladies immaculate antique living room!
Try explaining that one to the home owner!
GJ
