0 members (), 1,774 guests, and 7 robots.
#43353 10/11/04 04:10 PM
Hi,
I need to calculate how many RG59's constitute 40% fill in a 2" conduit.
I am having trouble finding any reference for this.
I have been looking for OD dimensions but havent had much luck..
any suggestions or help is appreciated.
Mustang
#43354 10/11/04 04:15 PM
I don't see where article 820 references conduit fill. I'm not sure that you are limited to 40% fill.
Ryan Jackson,
Salt Lake City
#43355 10/11/04 04:20 PM
Mustang:
Other than doing it the 'old fashioned way (measure the diameter & do the math) I can't put my finger on anything.
Did you try the mfg????
Venturing a guesstimate.....coax is visually 'close' to #4 or #6 THHN????
#43356 10/11/04 04:23 PM
hi,
the 40% fill requirement is a client spec..i found out that RG59 is 7/16" in diameter. THIS IS SIAMESE CABLE.
So i guess i could just do a calculation just like for a regular ckt?
This is also a combo cable with 2 #18 awg installed with the RG59.
Thanks for the replies.
Mustang
[This message has been edited by mustangelectric (edited 11-01-2004).]
#43357 10/11/04 04:56 PM
RG59 is only ΒΌ" OD.
Steve
#43358 10/11/04 05:47 PM
hi,
thanks for the replies...take a look at the following document. it has some interesting information regarding rg59 conduit fill.
http://www.brownstown.com/downloads/conduit-fill_require_.pdf
i got my dimension information from here: http://www.engproducts.com/products.cfm?ID=318
Still not sure. This is a COMBO CABLE/ COAX/#18 AWG PAIR
That was the best I had found until now!
Thanks for the replies..
regards
Mustang
#43359 10/11/04 06:47 PM
Mustang;
This is "Technically" [Linked Image] known as "Siamese" or "Siamese Cable".
Installed apx. 100,000 KM of the stuff!
The PVC (CMR, Riser, etc.) type Jacketed Cable has a larger O.D. than the Plenum (CMP) type Jacketed Cable.
Also, the Plenum Rated stuff pulls through Conduits better, but costs 2× - 3× the $$$ of PVC (Riser) Cable.
Cable Manufacturers will have the O.D. displayed on their web sites.
Scott35
BTW, thanks for the links! Will check 'em out.
#43360 10/11/04 07:47 PM
I am interested for the same information for Cat 5. I know I can calculate it from the tables given but I would like a chart for Cat 5 in emt if it is available.
thanks,
GJ
#43361 10/11/04 07:47 PM
e57 Offline
The 40% fill req. is more of a TIA/EIA req. rather than NEC req.
If you do tele/data, or CATV etc. you may want to check these out. They are not all of the standard in it's actual format, but seeing that the go for $200 bucks each, these trunkated versions/explanations are just fine. Also very informative.....
http://web.anixter.com/Anixter/anixter.nsf/Standards?OpenForm
Just looked at them again, the pages have changed, they used to have a lot more information on them before.
[This message has been edited by e57 (edited 10-11-2004).]
#43362 10/11/04 09:21 PM
Hi,
I thought the Siamese cable was a FLAT type cable with the conductors run side by side more like a UF cable?
I thought the COMBO cable was a ROUND cable assy that is more like a MULTI COND TRAY CABLE?
I am working on a project where there are a lot of video cameras. Is RG59 not an outdated cable? It seems that all I ever hear about anymore is RG6..Is RG6 more digital friendly?
Thanks for the replies..very interesting information...you never know when this type work comes along..and it helps to stay informed.
regards
Mustang
