169
7
We use bulb lube on every bulb we install. It works great. The only place I have seen it is at the check out lines at Menards. It is a little orange container that simialar in size to Carmex lip balm. It costs about 3 or 4 dollars, but it is well worth it.
Bring back brass-base bulbs! (Say that five times real fast!!!)
Hmmm... "Bulb Lube" sounds interesting- I don't know how many times in my old vehicles that I've had to use pliers to get out the broken 1157's due to seizure in the socket.
As for the KOPR-SHIELD(R), there are certain applications where it is truly indispensible, though I would steer clear of using it as an anti-seize for bulbs. I see that they also sell it in one-gallon cans- WOW! That's more than one or two terminal and conduit-thread coatings...!
No wire bias here- I'm standing on neutral ground.
KOPR-SHIELD(R) is a suitable product for compliance with 300.6(A) Don
C-H You mean like a light bulb? Thanks, after a long week I needed that. Actually I meant ... aw crap you know what I meant. De-ox runs when it gets hot. What about the other stuff?
Thanks, I got the stuff at Menards, which I'll try. The ingredients are mineral oil, polybutene, trimethylolpropane, trisostearate, isopropyl myristate, hydroxy stearate acid. Any chemists in the group?
Dave
use vaseline it work's good I use it alot for outside lighting I got this tip from back in the day when you would use srew in type bulb's for fish tank's
I did a google search on Dave55's stuff. It looks like a treatme nt for pruritus Where are you putting these bulbs?
HEY, KEEP IT CLEAN! I put bulbs in sockets just like every other electrician.
Dave
Vaseline is good stuff.
We use it here to lube the sliding contacts of the reversing contactor. 1200Amp at 72v dc.
TW
CDS
Nicholson Ga
