0 members (), 1,001 guests, and 10 robots.
Page 3 of 3 1 2 3
#42904 10/10/04 07:50 PM
I cannot imagine it mattering.
I like to group my breakers according to function (supanels, HVAC, appliances, lighting, recepts) and leave empty spaces between functions.
#42905 10/10/04 09:09 PM
twh Offline
I like to split up the heavy loads to reduce heating of the breakers.
#42906 10/11/04 10:26 PM
5 or 6 amp lighting breakers???????????
I need to visit the Non US portion of this site!
Power to the people
#42907 10/12/04 01:53 AM
Pat - Remember, the mains voltage is double over there.
#42908 10/12/04 05:59 AM
Yep! You can actually get 3A breakers from some manufacturers now, intended for feeding dedicated circuits for smoke/intruder alarm systems and such like.
You're most welcome....... [Linked Image]
#42909 10/12/04 04:08 PM
hi,
i also divide my panels...top half for ckts coming in from above..bottom half for ckts coming in from bottom..if possible
makes a neat installation..
i hate a messy termination job!
mustang
#42910 10/12/04 06:21 PM
What size wire do you run for a 3-amp dedicated circuit? Is it thicker than a human hair? [Linked Image]
Power to the people
#42911 10/12/04 06:28 PM
Just about.... [Linked Image]
Actually 1 sq. mm is the smallest permitted size here, equivalent to about a #17 AWG.
#42912 10/12/04 06:49 PM
Sorry I don't know of any pictures of a split-bus panel I mentioned above. Perhaps a quick description would suffice.
Take a main lug panel (no main breaker at the top) and cut the bus bars in half after the 12th breaker. This allows only 6 double pole breakers at the top of the panel, thus conforming to the "six disconnect rule" in the US. One of those double pole breakers then feeds the lower half of the panel where all the single pole lighting and appliance circuits are. Hope this helps.
[This message has been edited by Pat@Amber (edited 10-15-2004).]
Power to the people
#42913 10/12/04 07:37 PM
e57 Offline
Page 3 of 3 1 2 3
