0 members (), 444 guests, and 10 robots.
#40703 08/01/04 11:49 PM
Need advice on the best testing equipment to test hid and flourescent lighting. Including bulbs ballasts and starters and capacitors. What are you guys using out there?
#40704 08/02/04 10:09 AM
Master:
We use 'troubleshooting' instructions provided by mfg. Also, a known 'good bulb' & a digital voltmeter for output and cap testing. THe ballast mfg sites have troubleshooting suggestions, and output info available.
(Advance; Universal; Valmont, etc)
#40705 08/02/04 10:35 AM
I use the known good lamp approach. First change the lamp, if that's not the problem, replace the ballast. On HID, since most ballasts come as a ballast kit, replace all the components. There are lamp testers available and I have one but rarely use it. This saves a lot of time and IMO money, since I don't have to go back a few weeks after I've changed the capacitor in a fixture to change the igniter.
