578
9
I just received a magazine from Fluke and was wondering what kind of testers you use. I'll be honest here and say I'm a little cheap. I went to my truck and I have a GB digital multi-meter, a GB circuit tracker, and a GB pen type non-contact voltage probe. I probably got them all at the local hardware store. I've never bought or used a megger. Aside from the expense, I think I'd be afraid to lay a Fluke down on the jobsite.
What do you use?
Dave
Big Fluke fan here.
I keep a model 87 DMM in the truck, along with an 80i-400 clamp-on AC current probe. For more sophisticated testing, I drag out a 123 ScopeMeter. And a Fluke non-contact voltage detector lives right in my toolbelt.
Other gear includes a Supco megger, Harris toner/tracer set, and a homebrew telephone "buttset" (El Cheapo corded phone w/zip cord and red/green alligator clips attached).
My electronics testbench has a Fluke 8060A DMM, along with a Tektronix scope, a couple HP signal generators, and a handful of Heathkits (remember those?).
[This message has been edited by NJwirenut (edited 05-26-2004).]
In order from the most used to the least:
Greenlee BEHA Unitest
Etcon polarity / GFI test
Ideal Pathfinder for USOC, CATx & coax (with toner)
Generic VOM ~$12, less if I find one
Non-contact volt sniffer
Amprobe clampon
Generic buttset
Ideal ABS (Almost a Buttset)
Amprobe open finder
Al Hildenbrand
I too am a big Fluke fan (investor). I have the Model 87V and the i1010 AC/DC Current Clamp.
For those who fool with network wiring on a regular basis they make a wonderful series of handheld network testers. I bought the MicroScanner Pro and wonder how I ever did without it.
[This message has been edited by Mean Gene (edited 05-26-2004).]
I use a combination of Fluke,Robin,Megger,Martiundale and Metrohm test equipment
My meters. Roger
1 - cheap clamp meter for most use.
1 - Fluke 87 III with clamp for more accurate readings,
1 - cheap digital megger, because I don't want to be responsible for changing a 100 HP motor unless I'm really sure.
assorted - unreliable volt ticks.
1 - apprentice to check wires after the volt tick
An amprobe ac/dc clamp on multi meter is the best value for the money, I've been using them for ten years with no problems.
First of all, this is NOT an ad, and I'm not getting paid in any way... Secondly, I own an (according to Fluke) an exceptionally accurate Fluke. That said, I reccomend someone else.
FIeldpiece. They make meters for Ideal. The model that they market to the HVAC market is a 'stick' that easily fits in a pocket. Slip-on heads allow assorted additional uses, such as an amp-clamp, true-rms, temp, etc. Heads can be bought as you need them. Leads have interchangeable tips- need an alligator clip, change the tip. Check out their website.
Available at HVAC suppliers.
... I've got...an Amprobe AC/DC3000,an Etcon solenoid Voltage/Continuity Tester,an Ideal "pen-type" inductive tester,a Fluke "pen-type"inductive tester,a Fluke TS1000,ammeter/digital voltmeter,ohm-meter,2 Ideal circuit breaker identifiers,an old analog Heathkit VOM,...and my trusty thumb and fore-finger.. ![[Linked Image]](https://www.electrical-contractor.net/ubb/smile.gif) Russ
